Door Trim, 53 Hornet
fliptop
Need the following door trim....
I should have one of those, I’ll check tonight or tmrrw0
If Cheyenne dosen't have one I have plenty.0
I’ll be home in a little bit and I’ll check. I apologize for the delay, my wife had the flu or a cold for a couple of days and my daily drivers have been acting up and needing work.0
Yeah I have that trim. Are you missing any other trim?
yes need the trim attachment strip under both front doors.jc0
Do you mean under these corner pieces or at the bottom edge of the door?0
Bottom section right below the windows used to attach door molding and corner pieces.33" L x 3/4" W0
Ok I’ll check in a couple of days0
Any luck?jc0
I didn’t realize that there are two of you guys wanting the same pieces. Are you working on a car for another guy?0
No I am not
