How do I Re-connect This Linkeage ?
Old Fogey UK
I am trying to re-connect the ball joint on the end of the cross rod from the accelerator pedal to the rod that connects it to the carburetor on my 1934 Hudson.
The ball joint has to fit into a slot on the end of the carburetor rod and is held in place by a spring loaded plunger on the end of the carburetor rod.
I can't find a way of holding the plunger down to be able to insert the ball joint into the slot.
I'm sure there's a knack to doing this - does anyone know what it is please ?
If it was me I would be holding the link in a vice and also unbolting the ball from the carby. Use a suitable skinny tool to depress the spring and push the ball in.0
Old Fogey UK said:I am trying to re-connect the ball joint on the end of the cross rod from the accelerator pedal to the rod that connects it to the carburetor on my 1934 Hudson.
I'm sure there's a knack to doing this - does anyone know what it is please ?0 -
Thank you both for the advice.
The collar on the rod is fixed so I did it Bob's way - and it worked !
Once again, many thanks Bob.0
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 75 Hudson 8
- 597 Vehicles
