42-47 Wiring Harness firewall connectors wanted
I got a harness for my 46 PU from Providence advertised as cab and engine harness. Wires to engine bay were cut at the firewall. I found part of the connector and called them and told them that if the connector were there it would not be usable after 70 years especially in the NorthEast (where they are). Well, we can sell you an engine harness. No thanks, I'll just wire it from there myself a lot cheaper. And I did. Not happy with them.0
Thanks Uncle Josh. I can make the correct factory harness and Brillman, which is a short drive from me will loom it. I’ve already done the OD harness and connector. I just need the connectors for the dash/engine harnesses0
