Need a Generator GAR 4702 or Armature Gar 2077 1936 Hudson Terraplane
mitros
You can fit just about any later generator, with a suitable regulator, up to 1955 Hudson, and incl. Chrysler, Studebaker and Packard.0
How much rewiring is involved in changing to a different generator that uses a regulator? The 36 Terraplane generator uses a cutout instead of a regulator0
mitros said:How much rewiring is involved in changing to a different generator that uses a regulator? The 36 Terraplane generator uses a cutout instead of a regulator
The only extra wirong you will need is from the field terminal and armature terminal of the generator to the regulator. The current wire from the "Bat" terminal of the cut-out goes to Bat terminal of the regulator. That's all there is to it.0
- 105 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
