Camshaft
blondwookie
Hello to all. I know that this topic has been talked almost to death. What I'd like to know about is hopefully simple.
I'm now working close to home again. I'd like to know what is the best cam grind to use with the 7X engine that I'm planning to build using my stock 1955 308 engine.
In the past, I have used Delta Camshafts of Tacoma Washington. I have spoken to them recently about grinding my cam. I just need to know the ideal grind for soon to be built 7X 308 engine.
Thanks everyone for any and all input.
Wookie
Wookie
Use the '56 mech grind if you can find one!
https://openforum.hetclub.org/discussion/167650/hudson-camshaft-profiles
I’d suggest giving Isky a call & talk to them. I’d imagine they’d have more experience with the Hudson big 6.0
I'll be using Delta Cam in Tacoma Washington. They have ground many Hudson camshafts0
