51 hornet trunk rocket emblem location
The dimensions might be different between coupes and sedans since they both have different trunk lids.0
2 door version0
i have found some pretty good pictures searching the net, and am going to use these to scale up the location of the trunk emblem and drill the holes in the truck lid, but before i do , i posting one more time to see if someone can get me true measurements from an actual vehicle.
I would grab your club roster and look in the Member Vehicles By Year section, find someone with and identical 51, call them up and ask them to take measurements. If you are just going to take a guess lots could go wrong because of the emblem contour and the trunk contour and also the inner trunk support structure. Be sure to look under there. I have a 54, no help there. Hope this helps!0
club roster?0
Have you ever read the heading to this forum you are on?0
