Twin H Conversion?
Hello, I found a twin H exhaust manifold and intake, but the description on the intake says; " It has the tighter mounting stud spread for the wasp carburetor .
The carter carb for a Hornet engine is a carter wa-1 968s and the
pattern is too close to mount the Hornet ( 7X ) carb." So would this fit on a standard Hornet 308? or just the wasp? Thanks
Update, I've found it will bolt on but only fits the wasp carbs. Will wasp carbs run ok in a hornet?0
My opinion is that it will probably run ok. I would be prepared to change metering rods, If I was going to use it, and possibly jets as well.0
- 115 Hudson 1916 - 1929
