Clutch oil
What clutch oil can I use in my 51 hudson
Wildrick sells it. Many of us have been using Dexron transmission fluid for decades.0
There seems to be a number of different Dexron transmission fluids available. Do you suggest any particular one or does it not make any difference?54coupe said:Wildrick sells it. Many of us have been using Dexron transmission fluid for decades.0 -
If you go with Dexron transmission fluid go with Dexron 3. It is the only one that has come up every time on this topic.
I've tried dexron 3 and always had a shuddering feel. I had an antique can of Hudson fluid from the 1950s and thought why not crack it open and give it a try...no more shuddering... In the meantime I bought a few bottles from the het shop for future use. ..so if dexron isn't working ..get some Hudson oil cheers ken0
Wildricks sells the clutch fluid:Alternatively, I have heard of a home brew (Never tried it myself but it seems plausible):2 oz of Marvel's Oil
2 oz of Dextron 3
2 oz of 10W-30 motor oil
