General 308 Questions
beaverbikes
So far my experience is limited to a 53 Hornet with dual range Hydramatic. Now I'd like to go look at a 51 Hornet parts car, condition unknown except for a couple photos. Here's what I'm wondering: Is a 51 308 the same engine as a 53? And when it comes to the transmission, does a Hydramatic use a different flywheel than the 3 speed? I have a 51 Commodore in another state to drag home, I know the engine is pretty worn. It has 3 speed with OD, how about fitting a 51 308 in there?
Thanks a lot and if I do all this I'll join the Hudson club!
You can pretty well interchange any engine 1948-54, but there are differences in pre'50 versions, having a narrower block. The hydramatic do use a different flywheel. It's been know to swap a Hornet engine for an 8, and vice-versa. Of course 202's were limited to the Jet and '55-'56 wasp. '48'-49's had either a 262 6cyl, or a 254 8cyl, and the first 232 was 1950, and thru to '54. 308's went from '51 to 56 ( and '57 in Australia), But the '55 '56's had a different flywheel and other things to make them compatible with the Nash body.0
Transmission crossmembers are different from stick to automatic, and stick crossmembers are welded in.0
Also, the floorboard above the transmission differs as well.0
54coupe said:Also, the floorboard above the transmission differs as well.0
Thanks guys.0
- 102 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 558 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
