stuck valve keepers on 54 hornet engine
karl
I can't get #6 intake to free up from the keepers. All other valves came right out. Valve is free and comes up when using flathead spring compresser. I tapped on valve head but no luck. The keepers are stuck in the spring retainer. Has anyone experienced this? I don't want to pull the engine. I can rotate the retainer with a pair of vise grips but turns hard and only about 1/4 a rotation. No room for any other movement Any suggestions would be Appreciared, Thanks, Karl 860 460 9606
Your going to have to hit it hard. Punch or chisel on retainer.0
Should the spring be compressed when hitting retainer?0
call a mechanic !????0
Yes , compress the spring. It's stuck on something, you'll find out what when you get it out.0
Soak it with PBlastrr, ATF/acetone or marvel mystery oil0
Lostmind was right Hit retainer with hammer and punch and it came apart. Thamk you0
File it away in your memory bank , you'll be able to help someone in the future.0
Make sure you plug the oil holes in the bottom of the valve chamber first! Not fun having to take the sump off to retrieve a keeper.0
- 102 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 558 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
