Regulator
Ok here we go. B terminal (battery) goes to starter solenoid, B terminal on horn relay and terminal 1 on the OD relay. F ( field) terminal goes to the field terminal on the generator. A (armature) terminal goes to the charge light on the dash, terminal 3 on the OD relay and the A side of the generator.0
Thank you0
