Clutches, Pressure Plates & Flywheels
I have a 9” in my 37 Hudson which is bad. I am looking to change to a 10” setup. Will all 10” items work or are there only specific years that will interchange? What are the differences & please show pictures if you can. I have a pressure plate & clutch disk but not sure if they can be used or what I’m looking for in a 10” flywheel. Thanks
I have a 1935 clutch in my Hornet, so yes, any 10 inch unit will work.0
Be Careful as there are several different flywheels make sure everything lines up with the pressure plate.0
