1922 Hudson Front Spring Rear Shackle Bolts Wanted New/Used
Donald
Hello My Hudson friends , I am in need of 4 good used shackle bolts that go to the rear shackle of the front spring. I suspect many other years were the same. They are 4 1/8" long 11/16 on the big end with a 9/16 F thread on the small end. Can you help? Thanks, Don in central Ohio. 740-816-4284
Ask also on the 16 to 29 group site. If reqd you can also use 2 bronze bushes one inside the other.0
Thanks for your suggestion
Check your PM Donald or email me at HETgtkristi@comcast.net (remove the HET) Gert0
