Spokes
https://issuu.com/vintagecarclubofnewzealand/docs/bw341_output_web/43
Vern Jensen of Aotearoa Wooden Wheels. The link above should take you to the advert.0 -
the other option is to make tin shims and flare the tin on the inside of rim ...
Be sure that if you dismantle the wheel spokes you clearly number them and refit in the original position to maintain circularity and fit. The shim method works. Use a paint tin to make the shims out of. it is a tricky operation to get them back in place. I use a large dinner plate size round piece of flat steel with a long threaded stud. With the wheel on the bench ( with a hole drilled through the bench), mount the spokes in a cone shape and draw into position. Hammering into position is virtually impossible. Incidentally, if you do not number the spokes you have one chance in 479,001,600 of getting them back in the original position. I kid you not!0
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
