Headlight relay
Check Ebay. There are usually are one or two on there most of the time. I have several 12V ones if anyone needs one.0
These are mine , on the HAMB forum
NOS 6 volt head light relays | The H.A.M.B. (jalopyjournal.com)
I have one dual 6 volt , and 4 single 6 volt.
NOS Standard brand
Roy0 -
Look for an Echlin HR300 relay. They crop up on ebay and other places selling old NOS gear.
John a member of your you HET Chapter Jim Spenser sells kits with the 6 volt relays for Hudsons.0
6 Volt relays can be found on Amazon just search for 6 volt relays and two should come up. One is Temco 30-40 amp the other is Durakool 40-60 amp I bought a couple from there two weeks ago...AS SIDE NOTE I am no longer making the kits and selling them. I have been using the Durakool relay on my Overdrive for 10 years now.0
