Swarf on drain plug
WABOOM
Hey guys. I changed my oil today and there is swarf on the drain plug again plug like there was last fall. The magnet is 3/16 by 7/16 long for reference. I have been using 15W40 diesel oil. I just wanted to run it by the HET brain trust to see what you guys thought. Hopefully my cam is not self destructing. Would you be worried?
Thank you0
In my lifetime experience of Hudsoning I would say that is about normal. Perhaps you could drop the pan and do a clean out if this is a splasher. Please change from Diesel oil which now has NO Zinc in it to a good modern motor oil. It's past time to use diesel and the additive package is not suitable to gas engines.0
Is this an original or rebuilt engine?0
37 CTS said:In my lifetime experience of Hudsoning I would say that is about normal. Perhaps you could drop the pan and do a clean out if this is a splasher. Please change from Diesel oil which now has NO Zinc in it to a good modern motor oil. It's past time to use diesel and the additive package is not suitable to gas engines.0
10w300
Castro makes a 10w30 that is for older cars and has the zinc. If you can’t find that just use 10w30 of your choice w a zinc additive that you get at the parts stores. Otherwise there isn’t anything wrong w running 15w40 diesel rated oil. This is coming from a diesel mechanic and motor head.0
Thank you.0
Also, the oil I use is the "Off highway" Heavy Duty Diesel oil, not the new "Low Emissions" oil.0
WABOOM said:superwasp said:Is this an original or rebuilt engine?0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 605 Vehicles
