Replacement flywheel ring gear
dave11
Anyone know of a supplier for a replace starter ring gear to fit a 52 308?
Dave
Dave
Hydramatic or 3 speed?0
If it isn’t broken I believe you can rotate the ring gear to a new position on the flywheel.
regards, Tom0 -
3 speed0
I've heard of guys simply taking the ring gear off, turning it around (so that the worn part is no longer the mating edge) and remounting it. That is just general knowledge on my part, and not something that I know to be specific to Hudsons. I don't know why they would be any different, though.0
James P. said:I've heard of guys simply taking the ring gear off, turning it around (so that the worn part is no longer the mating edge) and remounting it. That is just general knowledge on my part, and not something that I know to be specific to Hudsons. I don't know why they would be any different, though.0
JasonNC said:James P. said:I've heard of guys simply taking the ring gear off, turning it around (so that the worn part is no longer the mating edge) and remounting it. That is just general knowledge on my part, and not something that I know to be specific to Hudsons. I don't know why they would be any different, though.0
Thanks guys, all good advice.
I will get in touch with Jason, if that doesn’t work out I can give this one a 1/2 turn
Dave Eddie0 -
I have built up the teeth with arc welding and re-ground with a disc grinder on my Essex. Haven't dared to try and remove the ring gear. Modern stainless electrodes are wonderful things.0
Dave, if you do not source a new one, rotate it 1/3 of a turn.Regards, Tom0
Just a question
1/3 of a turn =120 degrees
In a 6 Cyl the engine will stop on a compression stroke which = every 60 degrees.
Would it be better to turn the ring gear 30 degrees in between compresion positions?0 -
The flywheel stops in one of three positions, approximately 120 degrees apart. Since 1-6 move together, 5-2 move together, and 3-4 move together, that's only three stopping points. You want to move the ring gear 60 degrees from it's present location.0
Thanks 54 coupe. Regards, Tom0
- 103 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
