Lifters
blondwookie
I know that this topic has discussed many times over the years. I do know that there are no sources for hydraulic lifters. Just maybe some out there has some extra hydraulic lifters.
At this time, I'm soaking my hydraulic lifters to get the years of vanish from setting unused. Those that won't loosen up, I'd like to replace, before I send them and my cam to Delta Cam in Tacoma Washington to be reground to a performance cam.
Thanks for any help in advance, Wookie
Soak them in lacquer thinners works best.0
There is an opportunity to make something for the Hudsonites out there. I would like some hydraulic lifters. When you put headers on your Hudson it is a pain to adjust the valves. Not possible without removing them!0
This old thread may be of some use?
https://openforum.hetclub.org/discussion/168954/308-hydraulic-lifters
