Changing or cleaning filter in oil bath air cleaner
Does anyone one know if it’s possible to take out the filter in an oil bath air cleaner and either clean it or replace it?
Yes it can be replaced Fram makes them don't have the model number off hand someone will chime in on it I'm sure0
The filters in oil bath air cleaners that I've seen, look similar to coarse steel wool between two heavy steel screens. I rinse them in a bucket of gasoline and shake them off and reinstall. I have used a bucket of Simple Green also. Submerge it and agitate, shake around, twist back and forth, etc., then rinse well with water, and let it drain well overnight before reinstalling.0
oil bath oil bath filters are pretty efficient. If the medium is still in place, just clean and service per the maint manual..unless it says clean with gasoline.. use mineral spirits or perhaps kerosene.Regards, Tom0
If I’m not mistaken some where fitted with coconut hair and if you use gas or kerosene it will disintegrate
just a thought0 -
50SuperFalcon said:If I’m not mistaken some where fitted with coconut hair and if you use gas or kerosene it will disintegrate
just a thought0 -
superwasp said:50SuperFalcon said:If I’m not mistaken some where fitted with coconut hair and if you use gas or kerosene it will disintegrate
just a thought0 -
50SuperFalcon said:superwasp said:50SuperFalcon said:If I’m not mistaken some where fitted with coconut hair and if you use gas or kerosene it will disintegrate
just a thought0 -
Also after cleaning the filter and letting it dry, I thought you were also supposed to wet that medium with fresh oil.0
cheyenne7271 said:Also after cleaning the filter and letting it dry, I thought you were also supposed to wet that medium with fresh oil.0
I guess the question comes up does one of the other orphan car groups have a manual that indicates how to service one? Maybe Packard ,Nash ,Studebaker ?0
This is actually a good read and explains why the Service Manual says to oil the gauze 'standard' element, but not the true oil baths with the coconut shells. True oil baths oil themselves with oil saturated air.
Although, I love the PC move of telling you not to use kero without naming an alternative.
https://www.hagerty.com/media/maintenance-and-tech/old-fashioned-air-cleaner-service/
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
