IAT 4009B Distributor 12 volt condenser part number
Bitburger
I'm switching over to 12 volt and understand that if staying with my IAT 4009B distributor that the "6 volt" points, cap and rotor remain but the condenser must be changed to 12 volt. So, can anyone please provide a part number/application for the correct 12 volt condenser?
Condensor is not voltage rated, only microfarads. Must be in range .18 to .22 uf.0
As I said, voltage is immaterial. Just use the same one.0
