Starter motor question
I have an Autolite MAB 4075 starter motor in my 39 Six. I have been looking to find a core to rebuild as a spare. I have come across an MAB 4076. Best I can find the 76 covers Nash and Hudson 37-47. Can anyone shed more light on this as I wouldn't want to build it if it won't fit.
Val, Actually the correct starter for your car was the MAB 4100. The 8 cylinder model used the MAB 4075 as well as the MAB 4100 The 4075 being the slightly stronger starter although apparently you could still use the slightly weaker 4100 ( go figure) Anyway both will work on your six. Call me if you want Val I have a couple of 4100 cores if interested.0
Here's what the Auto-Lite Service Parts Catalog, 1937 edition, has to say:
models 90 & 98: MAJ-4057 (this may be a typo)
models 92-3: MAB-4075
models 94-5-6-7: MAB-4075
You can also find some starter listings on a Hudson factory bulletin found at
https://openforum.hetclub.org/uploads/FileUpload/47/c38f42b41486ec5b903b1149c5ecb5.pdf
Ivan, so 4075 is what the 92 is supposed to have? Thats the way I read it to be.0
So 4076, can I use that?0
Val
Here is more information I have from manuals as well as an article from WTN Sept/Oct 2006 by Walt Mordenti.
In the General Information Bulletin , the note at the top states starters from 1936-1947 are interchangeable except for solenoid mounting.Hope this helps.
Ivan L.0 -
Thank you, Ivan, for this info and clarification. And thank you to all who have replied. The 76 will work in my car so I will rebuild it.0
Val
Where does it say MAB 4076 fits Hudson? Maybe an old Hollanders Interchange?0 -
It doesn't however I have measured the shaft distance. It is the same. I have measured the body distance. It is the same and it looks identical to what I have. Clocking is the same way. So I feel that it will work.0
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 554 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
