Driving my '50 C8
I agree with you Dan, but IMHO putting the 8 cylinder in the Step-Down frame was a step too far, particularly in r.h.d. mode. L.h.d. was not so bad, but here in the antipodes with the steering box, drag link, gear shift cable, manifolds, exhaust pipe etc. all crammed into that limited space it is a pain to get to the fuel pump, distributor, and oil pump. Jet is as bad, particularly the fuel pump. compared to the 20's and 30's models, servicing is much more difficult. I envy you people with cars as they were designed to be, with steering etc on the left hand side.0
Geoff, I see what you mean and I had not thought of it before you mentioned it!0
The straight 8 cylinder had done it's dash in most cars by that time. Pontiac. Packard, Buick, and Hudson still had them, but by the 60's they were all gone, and the all-conquering V8's were in. I agree though, the Hudson 8 is an incredible motor. Technology caught up with it unfortunately, with white metal bearings throughout, the mains needed line boring, and was still splash feed. When you consider it's pedigree, it evolved from the first Essex 6 of 1924, and lasted until '52, it was a great run. There is a story of the Hudson engineering department worked an 8 with pressure fed bearings, and 5" stroke, but management quashed it. This was 1952 or 30
I still have Bernie Seigfried's article on the early 50's H8 modernization experiment and his comment that the said engine could have run and hidden from the Hornet 6. However, by the time the experimental work was done, so were the days of the L8 and close behind the flathead engine designs. Hudson was however stubborn, the Jet 6 was the last "new" L6 automobile engine put into production. The fact that AMC and Chrysler kept an L6 going into the 60s is quite surprising. On the other hand, a company in Europe introduced, not too long ago a flathead propeller aircraft engine, all aluminum and very compact, with fuel injection and other modern features. it is quite an amazing thing to see the flathead design survive even in this form.0
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
