Starter button
            Debris/corrosion on the contacts. Disconnect the battery and flush with electrical contact cleaner (space around button should be adequate to get solution in). Let dry and hook the battery back up. It could be the solenoid, but simple things first.
            I just fought this for a long time on my 1942. Yes I checked and cleaned "everything".
In the end it was the clip/connector on the switch itself. The bullet on the end of the wire went into the clip but the clip was slightly sprung. I squished it a bit with a pliers, the wire went in more soundly, it snapped in and it has been fine since.0
 - 111 Hudson 1916 - 1929
