8 cylinder motor serial number location
            30000 = 1948-1950. Date codes should verify this date.
            Casting date of Nov. 8, 1938 or 1948. So in a 1939 or 1949 car... Is it a rectangle pan, or a wide pan at the rear? That will tell you if it's 39 or 49.0
Two pictures, no oil pan, head or crankshaft
            Cast in 48 for a 49 model year car.0
            Kerry, I will take a photo of mine tomorrow where the number is. It is in the front on the machined pad on the top near the exhaust manifold.0
            Between the first two exhaust outlets.0
            Deck surface, right front corner.0
            Here you go. Numbers were a little rusty but I think you can see where they are.
            Thanks guys, yes this is a different location than the 6cyl.49 418752 serial number0
 - 111 Hudson 1916 - 1929
