Bleeding brakes
If I want to find in the forum about troubleshooting stepdown brakes, where do I be begin. Do I have to scroll down through all posts and hope to find something or is there a Search place?
I have found in my career as a mechanic, sometimes I just gravity bleed brakes. Other times I use a hand operated vacuum pump system. I hope this answers your questions. Otherwise you may have a bad master cylinder for your brakes. I've seen this problem more times than.i can count.0
You can search the forum. Maybe this link is what you're looking for.https://openforum.hetclub.org/search?Search=bleed+brake
