right side lean
my '28 essex has a right rear lean, about a good one inch tire pressure is good on both sides.
what might be the problem? i don't think shocks would do this and it's not a bent frame.
weak spring???
is this typical?
weak spring???
is this typical?
Jack up the left front and see what happens to the right rear. Measure the distance from the axle to the frame on all four corners. It will most likely be a sagged spring, or perhaps a broken leaf. If the left front is down it will tilt the whole body and be accentuated at the right rear.0
thank you, ill crawl under over the winter and explore
- 115 Hudson 1916 - 1929
