Removing 36 door handle
I’ve removed the two outer screws and two inner screws and the whole door handle mechanism is hanging on the door. I can’t figure out how to separate the inside from the outside! I’ve wiggled and pulled, it starts to separate and then gets hung up on something. I don’t see any screws or pins holding the two together. Am I just not trying hard enough? Any help?
Answers
Turn the handle around as you pull.
That worked. I had tried twisting and pulling but having the inside mechanism unbolted from the door didn’t allow me enough leverage. Once I screwed it back, I pulled the handle off immediately.
- 102 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 558 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
