Fuel Pump Question
Look at it! If it has two chambers it is a vacuum/fuel unit.
If you dont care about originality yiu can install a pump from an AMC 258-6. Direct bolt on just plumb it. I used one from a 1979 AMC Concorde on a 262. Works perfectly.
If you are still using the factory vacuum wiper setup, a double action would be highly recommended.
