1946 212 side cover water leak
It would be better to remove it and check for other issues and rust before attempting any fix.
As suggested above, remove the water jacket and make sure there’s no other issues plus clean out any accumulated gunk around the cylinders. There’s a distribution plate with holes that are needed for proper coolant flow so make sure yours isn’t Swiss cheese. Yes you can silver solder the inlet pipe to fix the leak.
Be careful removing the bolts & lock washers and replace them. If memory serves, they’re 5/16-18 x 5/8”. Use a suitable thread sealer and a new gasket
I used JB Weld putty and it's held up well.
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 89 Essex Super 6
- 28.5K HUDSON
- 549 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
