30 Essex Oil Pan Gasket Thickness
stev1955
Sometimes when I buy oil pan gaskets for my 30 Essex they are too short and need to be soaked and stretched to line up all the bolt holes so I want to cut my own. What is the proper thickness for these upper and lower gaskets? Thanks
Decided to answer my own question so I dropped the pan, took off the dipper tray and found the thickness to be 1/16" for both gaskets. Two 12" x 24" x 1/16" sheets of rubberized cork should take care of it, if anyone is following this question.
Glad you found the answer. Sorry no one was able to help but this info may now be of help to someone.
- 118 Hudson 1916 - 1929
