Identify this part ?
This is the 'H' frame the bolts to the underbody. The center support holds the driveshaft bearing and the rubber isolator bushings. This part actually was a mid 1948 add on. Earlier models didn't have this part. Was used up to the 1954 model year on short and long wheelbase models.
Thanks Lance- I couldn't locate it in my parts manual. I'll go back and look under the frame and transmission sections to see what other parts I need along with it.
