Adjust gearshift 52 double lever.
Hi
CAn anyone explain how to adjust gearshift linkages on a 52 double lever transmission in laymans terms.
Thanks
Steven
The 2 arms on steering column should be perfectly positioned to eash other. Remove clip or cotter pin and turn turn buckle either way to even them. Shift rods are threaded
Thanks did get it finally. Had to take apart and fully lubricate shifts perfectly now
