Scarebird Disc Brake Kit on 46 Pickup
Can someone who has installed one of these Scarebird kits on a 46/47 tell me what differences I need to be aware of when installing them on an older Hudson? I've heard the bearings may be different, but hopefully, someone who has been down this road can give me the exact details on what to be aware of.
Thanks in advance,
-Lance
  • charles4d
    charles4d Expert Adviser
    No different I put them on my 40 wasn't hard to do
  • charles4d
  • charles4d
    8270/- these work goodNapa Numbers Boar 53 Rotor-85802 48-85803 54 wheel Studs 641-3112 Ca wheel Nuts 641-2026 Cal Brs. Calipers SE 4594 5 Rebuilt SE 4595 75-5 Pads -Ts-. 728A bra These are organio pa Metallic grifutly higher they are the parts I used on my truck
  • charles4d
    I believe I used the same size bearing s and race only they were new ones
  • Awesome, thank you for the info, part numbers, and pictures! Much appreciated.
    -Lance
  • charles4d
    One other thing I was told by two people that have changed their vehicles over have seat belts the brakes will throw you thru the wind shield the brakes WILL stop you
