LA Bud disc brake conversion
Hi
I was wondering if there was anyone here that has used the LaBud disc brake conversion kit for their stepdown. I have one of theses kits that I am fitting to my car. If anyone has fitted this kit i was hoping you still had the fitting instructions. Looks fairly straightforward but just want to make sure i have done correctly.
Thanks
Steven
Steven did you get the message I sent you about the
Thank you so much . Do you know what type of discs and pads are used?
Regards
Steven
I think the rotors are for a lincoln from the rear and pads are chevy celebritie can't remember age is a bitch
I have a Labud kit on my 49 coupe. I used chevy monza calipers which worked but they had to be ground way down to fit stock rims. I may revisit mine with the Napa numbers Labud provided as shown in the pic in the previous post.
Anyone know how those Napa se-4594 calipers fit with stock rims as for the grinding?
I used all the items listed on my 40 no grinding was needed
Thanks so much for the info. Might order a few seeing as they are a little bit rare in Australia.
Thanks
Are your rims 15's or 16's ? and they are stock ?
15 inch
- 116 Hudson 1916 - 1929
- 96 Essex Super 6
