308s, hydromatics, 47 hood for sale or free
I have two 308s, a few hydromatic transmissions, and a 46/47 hood available. I would like to get something for the 308s. I paid too much for them. But I need the space so I have to let them go. The hydromatics are free. The hood will go cheap to someone in need.
I am in Virginia. I am willing to deliver up to a few hundred miles if someone buys them.
Do 308"s need rebuild. I have 1946Huson truck, and could use another hood as spare. What is the condition? Typically they rot on the left right front corners. I could use other 46-47 parts as well. I am in Delaware. Thanks Kevin Morrow 302ninefourthree8197
Kevin, I will send you some pictures and info via text.
The hood seems very solid. Some light surface rust. There is a small dent that can probably be banged out with one smack of a hammer. There is also a small split on the side.
One of the 308s is disassembled. The guy I bought it from said he had it checked by a machine shop and its in good shape. The other 308 was pulled out of a Hornet that was sitting. It has a hydromatic attached. The guy said he had it running before I picked it up, but I didn't see it.
Here are some pictures.
308s and hood are no longer available
How many hydros, and where are you located?
Nvm, just saw Virginia
The hydromatics are gone too.
- 112 Hudson 1916 - 1929
