50 Super oil leak
Hey all ,
My 50 finally blew out its front main , replaced it and the timing chain cover gasket . Still have a decent leak from the timing chain cover gasket, I used aviation gasket maker to seal it up (the really sticky stuff) .
Anybody with more experience have any insight into what I maybe did wrong ?
Thanks in advance
-Blake
What seal did you use? I have heard that the national #450084 seal is slightly thicker and seals better, but I do not have any experience with it.
You might need a speedy sleeve for the crank spacer, available at Napa or a good parts store.
"My 50 finally blew out its front main". I was thinking...
Is there pressure in the crankcase from worn valve guides and pistons?
Or just a worn old timing cover seal. Good comment made above.
Just a worn seal, unless your road draft tube is plugged w a dead mouse it shouldn’t have hardly any pressure.
Thank you all
I got it sealed up , easy job dispite how scary it seemed .
just a 75 year old seal that decided to bite the dust , car only has 38k on the clock .
I ordered a seal from Olsoens up in OR , not sure the number but it worked
- 112 Hudson 1916 - 1929
