Can Distributor be 180 deg out?
Hi all. I have a question:
My recently rebuilt '53 262 refuses to start. I have good blue spark to my points and to my plugs; getting good fuel to the intake manifold but no ignition. So I checked TDC with NO. 1 Piston and found the points aiming at 180 deg to my former mark on my distributor cap. I remember installing my distributor to the cam has the slot a little off center requiring just one proper position for the dist shaft. Is it possible my distributor could be 180 deg out? My rebuilder could have set the cam chain for firing at NO. 6 TDC?
Can I just set the distributor to fire in the new order as observed, or do I open my timing case and reroute the chain.
I am including pics showing the position of my flywheel and the position of the points (pointing opposite to my pre-rebuild setting.) I don't know if this position is universal for step-down engines, but it is 180 deg. out from my usual as I marked everything before tear-down.
Any ideas or experience is greatly appreciated; someone else may have had a similar situation.
Best Answer
  • Geoff
    Geoff Senior Contributor
    Answer ✓
    Yes, it can be out, but that's not the end of the world, just reposition the leads, starting with Np. 1 lead in the hole where the rotor is po8nting and then follow on clockwise 1-5-3-6-2-4
Answers
  • Sound like the oil pump is 180° off. Which makes the distributor 180 off.
  • Thanks, Geoff and Cheyenne. I will reroute my spark-plug leads. I thought my distributor had a slot that was just off center, and could go in only one way. I will make the adjustment and report back.
  • Geoff
    It can only go in one way, but it doesn't really matter if the leads are 180 deg. out, as you can just switch them around, much easier than removing the pump and realigning the gears. If you did have it around the wrong way, that is with the offset at the bottom wrongly inserted, the distributor would wriggle around with the distortion.
