Ghost of the Hornet! Inline 6 power and even a wet clutch!!!!!!
Here’s everything you need to know about the new 2026 Dodge Charger Sixpack lineup.
Like the Charger Daytona on which it is based, the ICE version utilizes the STLA Large multi-energy platform, and is broken in R/T and Scat Pack trims. Dodge will offer the car in both two- and four-door configurations, but the latter will be a late addition. In place of the EV powertrain, the Charger will feature two variants of the twin-turbocharged Hurricane inline-six shared with Ram and Jeep; Dodge has rebranded the engine as the Sixpack, harking back to the carb setups of yesteryear.
The Standard Output Sixpack engine will come in Charger R/T model, and provide customers with 420 horsepower and 468 pound-feet of torque. Step up to a Scat Pack model with the High Output Sixpack and those figures jump to 550 hp and 531 lb-ft. Every Charger will also now come equipped with all-wheel-drive as standard, allowing drivers to make the most out of that shove. Dodge says the Scat Pack is capable of ripping off a 0-60 mph sprint in just 3.9 seconds, as well as a ¼-mile time of just 12.2 seconds. The Scat can continue on to speeds of 177 mph, which beats out the Charger Daytona’s 137-mph top speed. The R/T isn’t as potent, with a v-max of ‘just’ 168 mph. A dual-mode active exhaust brings some extra throat to the Hurricane’s song, which now sounds BMW-esque.
DODGE
There’s no need to panic about the all-wheel-drive, however. Behind the engine sits a brand-new 880RE TorqueFlite eight-speed automatic transmission, which features a multi-disc wet clutch system. This means that drivers can disengage the front axle and send 100% of the power to the rear wheels at any given time. (The car will also automatically disconnect the front axle when cruising to help improve efficiency, which is a nice touch.) Dodge is leaning into this dual-purpose attitude by also including Line Lock in all inline-six-powered models, allowing for easy burnouts in the pit box (and definitely not in an intersection near you, of course). A mechanical limited-slip differential also comes installed in every Charger.
TOO Bad they used the Hornet name and pipsqueak hybrid SUV.
Wet clutches are still a thing it seems, my Mercedes C63 AMG has one too.
- 97 Essex Super 6
