29 Hudson Super 6 wiper motor
How much of the interior has to be taken apart in order to remove the inner panel to gain access to the wiper motor?
Best Answer
  • Geoff
    Geoff Senior Contributor
    Answer ✓
    Spring it out, or use a screwdriver to lever it out.
Answers
  • Just the header over the windshield.
  • header seems to be hung up at the ends by side trim?
  • thank you Im replacing all the top wood and want to get access to the bottom of the steel header for the bolts thank you again
