super six 1929
trumpet79
re my 1928 super six. I now have completed all the new top wood and installed a new vinyl roof. I used ash from wood I had sawn from my logs and white oak sawn from a tree from a friends back yard. i bought a juki commercial sewing machine to attack the interior later. this car has apparently been retrofitted with a later looking generator mounted on a pedestal in the left side of the engine. There seems to be a water pump on the right side connected to the bottom hose and a smaller group of pipe fittings connected to the right sid of the block with a couple if two eared flanges. Would this be where to drain the coolant? was this modification common? there is no apparent drain cock on this pump. Any ideas? thank you.
Pictures would help
- 97 Essex Super 6
