Advice Needed
I am currently stripping my 54 Hornet 4 door sedan in preparation for paint, but can not figure out how to get the stainless dressing off of the rear door. I can see that there are 2 clips on the side & 1 on the bottom of the door to firmly hold the bottom section on, but there must be some arrangement beside the screw on the backing strip holding most of it to the car. Question, does the upholstery on the door have to be removed in order to complete removal? Thanks for any help.---Cliff Minard.
remove the door panel, you should find four studs with nuts0
Thank you anonymous for answering my post. I will now proceed with removing the door upholstery. Cliff Minard.0
