Help with ID
There is a car body sitting "out back" in Grandpa's trees we would like to identify. We have no experience with Hudsons. There is a plate on the engine cowl wall that says Hudson Motor Car Co. Car No. 959885. Is this a number that can be used for year and model ID, or should I look for something else? It was a 2-door with "suicide" opening doors. It is a body only, no frame or drive train, so I can't get any help from those items. It is not in the best of shape, but we have toyed with the idea of trying to make a street rod from it.
Any information would be appreciated. I can get pictures if it would help, just tell me the angle you would need to see.
Thanks
Thanks
It's a 1939 (Series 95) Hudson Country Club Eight, which would be the long wheel base. Serial #s went from 95106 thru 9554902. Should have rectangular instrument pods. I have what's left of one of these out in the woods. Where is it and does it still cast a shadow?0
Thanks for the reply. I didn't realize it might be that old. I don't think there are any instruments left. What kind of engine did it have?
I might head out for a look again, maybe get a few pictures and measure.
Zip code 692120 -
Would have had a straight 8 engine with Hudson Power Dome cast into the head. 3 bore 4 1/2 stroke putting out about 128 HP. Block was 32.5 inches long. Unique in that the water jacket was external to the engine on the left side.0
That must have been some unique engine. I never knew of one like that. I cut down some grass and took some pictures, not a lot left there. It has both doors and the trunk door, though they are not on. Driver side door is pretty rusty. Without a frame it's pretty hard to estimate wheelbase. From center of rear wheel well to the firewall is about 85" so I would guess somewhere in the 105-115" area for actual wheel base?
I'll try attaching a side view picture, if you are interested in others I have front, rear, inside, and door pictures also.0 -
Oops! That looks like a 1934 Hudson Series LU Compartment Victoria. Quite a rare body. Would have had weighed 2895 and cost $875. The 254 ci 3 x 4 1/2 8cyl would have put out 108 HP Serial #s for those were 950000 to 968679. Nearest pic I have is a Terraplane which would be a 6 and have a shorter front end but looks like your body from the windshield back. I'll see if I can scan the pic and post it here.
Ah, I think it looks like this.0 -
CT wrote:That must have been some unique engine. I never knew of one like that. I cut down some grass and took some pictures, not a lot left there. It has both doors and the trunk door, though they are not on. Driver side door is pretty rusty. Without a frame it's pretty hard to estimate wheelbase. From center of rear wheel well to the firewall is about 85" so I would guess somewhere in the 105-115" area for actual wheel base?
A really sweet looking body for a 2dr! It's like an extended cab on a coupe!
It would be perfect for a hot-rod build - Don't let the rust discourage you and parts can be made for any rusty or missing sheet metal.0 -
Uncle Josh wrote:Oops! That looks like a 1934 Hudson Series LU Compartment Victoria. Quite a rare body. Would have had weighed 2895 and cost $875. The 254 ci 3 x 4 1/2 8cyl would have put out 108 HP Serial #s for those were 950000 to 968679. Nearest pic I have is a Terraplane which would be a 6 and have a shorter front end but looks like your body from the windshield back. I'll see if I can scan the pic and post it here.
Oh darn - bitten again by the "serial number bug!!!" LOL ROF That serial number was for the Models LT and LU - these were at the bottom end of the lineup for Hudson in 1934. They were on a 116 inch wb. Only 8 cylinder Hudsons were produced in 1934.
See what you can learn from my "General Information Handbook....:":eek:
Alex B0 -
Heres a 34 4 door Hudson 8 street rod.0
You wanted to see a Hudson 8. This one is the later wide pan with the aluminum head but the rest is the same.0
