Stoplight Switch For 51 Hornet
[Deleted User]
Can I get one of these from NAPA? Anyone have a part number or where to get one locally today? Thanks! Niels
  • Niels,
    I seem them (both NOS and NORS) frequently on ebay. Check it out.
    Dave
  • Dave53-7C wrote:
    Niels,
    Dave
    I saw that there's one on e-bay now but I'd like to get one today if possible.
    By the way, Do these just simply screw on and off or do you also have to bleed / refill the brake system?
  • Walt-LA
    Walt-LA Senior Contributor
    Bought mine from NAPA couple years ago. Don't remember part No. Walt-LA
  • 464Saloon
    464Saloon Senior Contributor
    Neils,
    I just put a master and switch in my car. I can't find the receipt right now, but if you call Randy at Haps Auto 422-1020 he can help you. He is getting very used to chasing down Hudson parts.
  • The local Napa still stocks those here, too.
  • J Spencer
    J Spencer Expert Adviser
    Stoplight switches are available at ADVANCE AUTO also,-- normaly a stocking item. This switch fit nearly all older vehicles with hydralic operated switch.
    Just unscrew the old one, screw in the new one, should NOT have to bleed the brakes. Neve had to on the many I change in years past as a mechanic.
    JIm Spencer
    JIm Spencer
    I had called Dave Kostansik and he gave me the part number, SLS 27. Napa has em and so does most auto parts places. I got it put on (and it works!). Thanks for the responses! Niels
