Transmission shaft.
Geoff.
150142 shaft.
Aussie Replacement by C&J gears number Z225-9 New Old Stock.
Cost $40.00 plus shipping.
It pays to shop locally and help keep a retired gentlemen put food on the table.0 -
Huddy42 wrote:Geoff.
150142 shaft.
You're a life saver (again) Les! Send it over and I'll even think about paying your for it!:p
Geoff.0 -
Geoff,
I see where you are still looking for an aluminium timing gear.
Over the last couple of days I have been digging around in some boxes of parts and came across an aluminium timing gear that someone had machined the rear of the gear to counteract for the bolts clearance. It has been used at some stage, do you want me to include it in your parcel and you can see if you can use it.??0 -
Yes, yes, and yes, please. Did I reply in the affirmative???? Just in case, Yes please.
Geoff.0 -
Geoff,
Your parcel is on the way Air Mail, you should get it in a few days.0
