Transmission shaft.
Geoff
Geoff Senior Contributor
I need a rear shaft for a '36 -'37 transmission, NOS or good used, part # 150142, 6 spline. Can anyone help please?:confused:
Geoff.
  • Huddy42
    Huddy42 Senior Contributor
    Geoff.
    150142 shaft.
    Aussie Replacement by C&J gears number Z225-9 New Old Stock.
    Cost $40.00 plus shipping.
    It pays to shop locally and help keep a retired gentlemen put food on the table.
  • Geoff
    Huddy42 wrote:
    Geoff.
    150142 shaft.
    You're a life saver (again) Les! Send it over and I'll even think about paying your for it!:p
    Geoff.
  • Huddy42
    Geoff,
    I see where you are still looking for an aluminium timing gear.
    Over the last couple of days I have been digging around in some boxes of parts and came across an aluminium timing gear that someone had machined the rear of the gear to counteract for the bolts clearance. It has been used at some stage, do you want me to include it in your parcel and you can see if you can use it.??
  • Geoff
    Yes, yes, and yes, please. Did I reply in the affirmative???? Just in case, Yes please.
    Geoff.
  • Huddy42
    Geoff,
    Your parcel is on the way Air Mail, you should get it in a few days.
