HELP NEEDED!! Cam for 8 cyl engine
I finally have determined why my oil pressure was gone in my 37 Hudson sedan's 8 cly engine........the gear cut into the cam to turn the oil pump has been worn off.
I dont know what years will interchange but I would take any good used, new or ? cams for the old girl.
Thanks!!
Thanks!!
Husker Nation wrote:I finally have determined why my oil pressure was gone in my 37 Hudson sedan's 8 cly engine........the gear cut into the cam to turn the oil pump has been worn off.
Thanks!!
You can use any camshaft from '34 through to '52. You can also get the offending worm gear built up and re-machined without too much trouble, and it will be better than the original.
Geoff.0 -
Mike Gajdek (sp?) in NJ was re-grinding 8-cyl cams. Xheck him out he might just have waht you ned. Phone number in the Roster.0
Thanks all, I appreciate your advise and sources for cam help!
If anyone has an extra cam shaft for sale, please let me know!!!0 -
Husker Nation wrote:Thanks all, I appreciate your advise and sources for cam help!
Check with Lester Harris (775) 267-2241, He might be able to help. Pacific time.0 -
Nevada Hudson wrote:Check with Lester Harris (775) 267-2241, He might be able to help. Pacific time.
Thanks for the lead! I am still looking for a replacement cam!0 -
Anyone doing stripped cams for the 6 cylinders?0
hudsonkid wrote:Anyone doing stripped cams for the 6 cylinders?
should have l8 cyl cam, will look wed am and get back to you BILL ALBRIGHT0 -
bill a wrote:should have l8 cyl cam, will look wed am and get back to you BILL ALBRIGHT
Thanks bill, I will wait to hear from you!0 -
What model 6 cyl cam are you refering to.??
hudsonkid wrote:Anyone doing stripped cams for the 6 cylinders?0 -
Huddy42 wrote:What model 6 cyl cam are you refering to.??
any stepdown 6's...
just curious....0 -
hudsonkid wrote:any stepdown 6's...
just curious....
HAVE A VERY NICE L8 CAM FROM A 52 COMM 8. EMALIL ME FOR PRICE albrighthudsons@msn.com0 -
If you need to have yours repaired, I have had Racer Brown to a bunch of work for me on old Chrysler and Porsche shafts. They will supposedly work on any camshaft you send them no matter what it is. Very reasonable too and a great reputation, they've been around forever. The last Chrysler solid shaft I sent them they put a performance grind on it and fixed some other problems and it was $100 flat. 410-866-7660.
Best Regards,0
- 994 Street Rods
- 174 The Flathead Forum
- 602 Vehicles
