A Tool that is worth the $
SuperDave
SuperDave Senior Contributor
I recently bought an air powered grease gun at Harbor Freight. I don't remember how much I paid, but it was cheap. This thing is great! I have used manual pump grease guns for 50 years. It allways :) takes three hands. One to hold the greasy gun, another to pump the handle and the third to hold it on the fitting. This thing grips Zerk fitting so well, that it's dificult to remove! No more leakage so the waste is Nil AND it forced some grease in some fittings that I was unable to lube with the hand gun. So If you have compressed air in your shop.. Go getcha one!
Dave w.
  • I've enjoyed using the one I have for a few years. They're inexpensive too.
    WE HAVE ALWAYS USED THE OLD FASHIONED WAY, BUT I HAVE A HUGE COMPRESSOR TO FUN ALL THE TOOLS AND A BIG SANDBLASTER, SO I THINK I WILL GET ONE. THANKS, BILL ALBRIGHT AT THE TWIN H RANCH
    whats even better that that (altho much more expensive) is the 14 V battery powered grease tool by lincoln. comes with 2 batterys. a charger and a carrying case for around $200. lot of guys that have multiple machines use these. the biggestt user of course is the heavy equip owner / operator.
    davidh
    davidh
    If you can aford it the batt. operated one is alot better than dragging an air hose around the shop.
    Chuck G.
    Chuck G.
    I guess if you have many many Hudsons and other cars that need greasing this is all good :)
  • rambos_ride
    davidh
    I saw a 16V unit at Harbor Frieght store today for 70.00 - I almost bought it...
    Dave w.
    Dave,
    On the one you bought, is the grease fitting on the end removable? Reason I ask is some of this junk I have around here has Alemite fittings, so I like to unscrew that Zerk squirter off the end and put on an Alemite one.
    Best Regards,
    Dave w.
    Just looked on their website
    http://da.harborfreight.com/cpisearch/web/search.do?keyword=grease+gun&Submit=Go
    and found a few: here's one:
    AIR GREASE GUN
    FREE 9' Hose with Purchase
    A must for vehicles, agricultural machinery, industrial equipment, and more. One-hand pistol grip air grease gun delivers 1200-6000 PSI each time the trigger is pressed. Comes with 6' extension. Can be cartridge-loaded or loaded with bulk grease.
    * Operating pressure: 30-100 PSI
    * Grease capacity: 14 oz.
    * Air inlet: 1/4' NPT
    * Net weight: 3-1/2 lbs.
    ITEM 219-0VGA
    $19.99
    $11.99 (SALE NOW)
    making plans now to go get one!
  • SuperDave
    AIR GREASE GUN
    ITEM 219-0VGA
    $19.99
    $11.99 (SALE NOW)
    That is the one. Yes the business end is removable. I found that the flex hose was the only one that allowed me to get all the fittings on a stepdown.
    Dave w
