Stabilizer Link Kit
Unknown
Does anyone have a modern part# interchange for the stepdown stablizer link kits? One that could be obtained locally, such as NAPA? Thanks, Scott
  • hudsonguy
    hudsonguy Senior Contributor
    Scott,
    Don't know the NAPA number, but if you can, I'd suggest you call Dale Cooper. You'll probably have your parts within a few days. Plus, you'll be certain they're right, and for a good price.
  • 464Saloon
    464Saloon Senior Contributor
    hudsonguy wrote:
    Scott,
    This is a good opportunity to go with urethane. Will improve the handling and will last forever. K-Gap has them or you can match yours up with the Energy Suspension catalog like I did for my 54. If you want I can pull the numbers when I am home. I believe the bar is 3/4 so all you need is a set of generic 3/4 diameter center bushings and I think I got the 7 1/2 inch end link kit from them. Comes with new bolts washers and bushings. I think the whole deal was around 30.00.
    Thanks for all the info. I ordered the link kit from Dale, but would like to replace the rubber cushions with urethane if you can tell me what I need to do that. Scott
  • J Spencer
    J Spencer Expert Adviser
    For stabalizer links for stepdowns chaeck out 78 up GM Malibus ,Regals, Grand Prix, Cutlass Supreme rear wheel drive link kits I believe the spacer bushing are the correct length. Available at local parts suppliers
    Jim Spencer
