1929 Super Six hudson parts needed
I am looking for a hood and radiator for a 29 Hudson Super six. Also looking for a wood pattern for the roof bows and small parts such as exterior door handles, steering wheel and control levers on wheel, 2 wire wheels and 1 extra split ring and other stuff. Please email me with available parts. Thanks, Jeff
split51 wrote:I am looking for a hood and radiator for a 29 Hudson Super six. Also looking for a wood pattern for the roof bows and small parts such as exterior door handles and other stuff. Please email me with available parts. Thanks, Jeff
http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/29hudsonsedan.msnw?Page=2 The girl and her boyfriend had some parts for sale from this 29. I have her email at home if you would like to try them. Where are you located and what 29 do you have? Thanks & Good Luck, Ron
http://autos.groups.yahoo.com/group/HudsonSuperSix16-29/messages Also try this message board. I have a 29 standard sedan but not many extra parts. Hope this all shows up on here...LOL My email is sultans@webtv.net0 -
Yes, Please send me her email address. It is a coupe, I will post some pics of it later0
I had to make the roof timber work my self for a 31 and I just copied the curve at the front and I found on mine the rear was the same but wider and did the same on the sides and made a whole lot of bows to go in the middle I screwede and glued the lot together and installed glue blocks to each cnr and to each side of the bows ended up super strong and inserted a piece of ply off set from the centre(towards the front) to take the light fitting and instead of using the plastic or rubber welting around the roof (as this tends to shrink and expand with the different temperatures) I used a early model A tee section to do the same job and rebated the timber work to take this on the sides, which can be screw fixed once the exterior hood lining is attached
when all together you can put a silcon bead around the tee section and get a water tight seal then finish bolting it back in place with the original interior
fittings
Ps the tee section (model A)was just about the perfect shape in its curviture
to the roof on my 31 I dont know what year it was as my previous body shop supplied it
Regards Mike0 -
Ron P wrote:http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/29hudsonsedan.msnw?Page=2 The girl and her boyfriend had some parts for sale from this 29. I have her email at home if you would like to try them. Where are you located and what 29 do you have? Thanks & Good Luck, Ron
Good heavens, that USED to be a Standard Sedan. I especially like the Camaro wheels. I will look around and see what odds and ends I have and let you know.0
- 174 The Flathead Forum
- 602 Vehicles
