Really have to pull the trans out through the car?
happychris wrote:
Through this whole thread i hope happychris got his question answerd. I think that was what we started to do. LOLI was trying to stop gear lube sepage from the 3 spd trans and OD in a 49 Commodore. Read the manual and it says to remove the front seat and pull an access plate from the floor to remove the trans and bellhousing as a unit. Is this for real? So you have to pull the trans / OD / bellhousing from the motor and out through the interior of the car if you need to service the clutch, trans, or OD? If this is really true, how do you keep from ruining your interiors and also how do you heft the unit out of the car - engine hoist? Sorry if this question shows my inexperience with Hudsons. My 49 is my 1st Hudson.
BST RGDS
GARY ( happychris )
LJ0 -
I did indeed - MANY THANKS
BST RGDS
GARY ( happychris )0
